FKR Mark II
Started by dano12, March 12, 2007, 09:58:07 AM
dano12
emilyandmiles
Impressive as always Dano.
Much admiration for yr builds and site.
The_Bloody_Omen
Hey Dano,
I noticed that on your parts placement diagram for the main PCB the 4.7n cap towards the bottom states the anode should be in the round hole. However in the schematic it says the cap should be facing the other way.
Which one is true?
I am pretty sure its the anode in the square soldering pad but just wanting to make shure.
Thank you for such an awesome build!
From,
The_Bloody_O
P.S. someone commented about how to re-size the pcb layout diagram. What you can do is take a screen shot of it (program: snipping tool for PC, or some weird comb for mac: its like mac + F4 i think) then spank that to a word doc, make sure it is wrapped tight and then you can re-size and print in till it matches up with an IC.
GGBB
Square cap pads are for anodes.  The schematic is correct.
