Beginner Question
Started by sirlcmd, April 15, 2013, 07:46:32 PM
sirlcmd
I just finished my first PCB board from the BYOC Classic Overdrive kit, but there are some splattered solder pieces on some parts. I heard I could use some alcohol and a toothbrush to clean it, is this true? I also was looking for ways to test it by just using a multimeter. This is my first build so I'm not going to make a testing rig yet. Any other things I should know before I put it in the enclosure?
Alcohol will not dissolve solder.  It will make some headway cleaning flux residue off the board (though I find it less effective than other chemicals), but flux is not solder.
If you do have excess solder on your board, I would recommend getting yourself a roll of "solder wick", also known as desoldering braid.  This will set you back between 5 and 8 dollars for a small roll.  It is VERY effective for absorbing excess solder or removing solder from pads when you want to remove a component.  It works best when you wipe a little bit of liquid flux on it.  But since you are just starting, and the smallest bottle of liquid flux will likely set you back $10 on top of the solder wick, I'll simply say that plain old solder wick works fine on its own too, so long as it hasn't corroded.
sirlcmd
I have some solder wick. I assume you mean it is safe to use anywhere on the PCB board not just on joints?
if the solder is on exposed copper traces, or component leads, you'll prolly need the solderwick. if it is just spattered on the board where there is no copper, or on a resistor body, for instance, you should be able to pick or peel it off with a sharp metal pick of some sort.
" I will say no more "
