Landgraff Clean Boost - Unity Gain Only
Started by Ofek Deitch, August 31, 2013, 07:03:39 AM
Ofek Deitch
Hi,
I've built a SHO with the Landgraff input resistor mod, and I'm having the same issue as the guy over here:
http://www.diystompboxes.com/smfforum/index.php?topic=94244.0
Bypass signal is fine, but effect on, its just the bypassed signal, but i can hear afaint crackle when turning the knob.
I'm using a J201 and this is the scheme used:
Voltages: (9v)
D: 2.2v
S: 1.1v
G: 0.3v
Thanks for any help!
- Ofek -
Davelectro
I'm afraid this is another case of "Crackle OK".
anchovie
Quote from: Davelectro on August 31, 2013, 07:27:09 AM
That's not his problem - he wants a booster and he's getting unity.
Quote from: Ofek Deitch on August 31, 2013, 07:03:39 AM
I'm using a J201
That's a JFET - this circuit calls for a MOSFET.
Ofek Deitch
Will replacing the J201 with a BS170 help?
Gus
Hi,
- Ofek -
The series input resistor is something you can read about in textbooks.
Ofek Deitch
#6
I replaced it and it works now!
Thanks for the help guys!
Background:
The gain you get out of a device can be computed as the transconductance (current change on the output per unit change of voltage on the input) times the load resistance, which is then modified by any feedback.
The transconductance of most MOSFETs is many, many times larger than the transconductance of a JFET.
That, *and*... the way that MOSFET was biased, a JFET in the same place has the Gate *forward biased*. Enough to suck-down signal.
