Yes.. Another stereo input question.
Started by Musician78, May 12, 2013, 10:42:02 PM
Musician78
I built an ABY pedal...
I used this and followed it to a t...
But the light(s) stay on when there is no cable in the stereo jack. What did I do wrong and how do I correct it?
kingswayguitar
debugging is frustrating eh?
i would assume you checked for solder bridges?
is the purple triangle in your diagram the jack tip?
i've never built a splitter but when i wire my stereo input jack i connect the ring directly to the (-)ve post of the battery. it would take me a minute to figure out how to do this in your case but does that give you enough to go with?
Musician78
Everything seems good.  Purple wire is attached to the tip.   It is frustrating.
Musician78
What if I added another ground from the ring to the negative battery terminal?
Hemmel
Quote from: Musician78 on May 13, 2013, 12:22:39 PM
You'd be doing exactly what Kingsway was suggesting.
I would suggest you link your sleeve connections to the middle-right pin of the left switch (where the negative battery is connected on your layout), disconnect the battery (-) from that pin and connect it to the ring of the input.
Keep us posted !
Bââââ.
Musician78
Actually yes.  I misread it this morning.  Thanks, I will try that and let you know.   :)
kingswayguitar
hang in there. even though i've never built one, i suspect your struggle is just a simple wiring issue. i suspect the led stays on due to reverse leakage, combined with my previous post. i was going to try to redraw something for you but haven't found the time. hang in there and let us know how it goes.
mark hammer says it's the easiest thing to built but there are always gremlins  ;)
Musician78
GENIUS'!!!!!    THANK YOU VERY MUCH!!!!!   I knew it had to do something like that but didn't alter or deviate from the drawing.   Again, thank you so much!   :)
Hemmel
Bââââ.
Musician78
How could I add a dc jack to this?   Everything I see indicates negative to ring of input and battery clip, positive to battery clip.  And another positive to V+.   Where is V+ on this?
Paul Marossy
Quote from: Musician78 on May 23, 2013, 06:27:54 PM
V+ is the positive leg of the power supply. So I guess you could say that V+ is the + connection on the DC jack (and the red wire on the battery snap).
Musician78
So I would only use two connections?   There wouldn't be a point in splicing the positive of the battery clip to put positive on both lugs...?  I know I must be missing something....
