Small Stone Phase Shifter Issue
Started by jshakesepeare, June 02, 2013, 07:59:06 PM
jshakesepeare
Cap is 2.93V on positive, 2.94V on negative terminal
jshakesepeare
Just shorted the cap and it worked! Replaced it and everything is perfect!
Thanks so much for helping me work through this problem.
For future reference, what can I do to allow me to fix by myself instead of posting for a similar issue.
Is the rule wherever the signal stops, that component either needs to be resoldered or replaced?
oskar
QuoteJust shorted the cap and it worked! Replaced it and everything is perfect!
8)
Quote from: jshakesepeare on June 03, 2013, 11:29:46 PM
You just need to do more troubleshooting. You can't always follow a signal with an audio probe but it's fast and simple.
From your first post:
QuoteI replaced the old electrolytic caps with new ones already.
How is your soldering? A common mistake is to not have a hot enough iron and also not putting solder on the tip so the heat transfer is slow. This will put more strain on the component than a swift action from a hotter iron.
jshakesepeare
The cap that was messed up was not one that I changed.
Thanks for all your help with this, I feel more confident that I can fix stuff myself next time
