STRIKER SMOOTH MOD
Started by Striker Amplification, July 08, 2013, 05:30:53 PM
Jdansti
Could you please take a look at this and let me know what you think?
Quote from: Jdansti on July 14, 2013, 05:07:07 AM
I'm a little confused about our capacitance units.
>.1mfd-.47mfd are good starting points, there really is no effect with a capacitor as big as .002, thats HUGE
0.1mfd = 0.1 microfarad = 0.1 x 10-6 Farad = 0.1 uF = 0.1 μF
What are the units for 0.002? When I see 0.002 on a schematic, I assume that it means 0.002 μF (2 nF, or 2,000 pF). If that's the case, then 0.002 would be smaller than 0.1 mfd and 0.47 mfd. Am I missing something?
WaveshapeIllusions
Oh, I see what that is. I couldn't see the image in the first post. It's kind of like bypass caps for more gain at the emitter/source/cathode, except in reverse. For something similar, look at EHX's The Mole/Hog's Foot bass booster. There's a cap in parallel with the collector load. For AC, that cap is part of the collector load and gain drops accordingly when Xc drops. I think it works a bit different in this case though, because the output is take across the transformer instead of at the plate. I don't even want to try to figure out the -3dB frequency. I mean, resistive load would be easy enough. A speaker though?
0.47UF        0.002UF is actually bigger than 0.47uf , it is actually almost 3 times as large. 0.001uf is the cap i was using on my treble booster.
Builds:Plexi superlead mkll 100,plexi superlead mkll 50, 59 plexi, 59 4x10 bassman, marshall bass and PA head 100, JTM45, modded JTM45-lead,JCM800 lead 50.
R O Tiree
Quote from: Striker Amplification on July 15, 2013, 04:47:22 AM
Whatever you're smoking, mate, I want some.
...you fritter and waste the hours in an off-hand way...
DougH
I'm still not sure what "POINT B TO POINT B" means on the schematic...
pinkjimiphoton
Quote from: Striker Amplification on July 15, 2013, 03:26:14 AM
Someone really needs to try this befor iam forced to upload a live video of MASS DESTRUCTION!!! :icon_twisted:
like, wtf, dude, way to keep a hippy in suspense..
lol
unleash the dogs of war!!! video is a must!
Slava Ukraini!
~Jack Darr
Jdansti
Is 0.002UF different than 0.002uF?  Are you calling both microfarads
pinkjimiphoton
that would be .002u, 2n or 2000p all the same value j
Slava Ukraini!
~Jack Darr
puretube
Quote from: DougH on July 15, 2013, 08:58:09 AM
(B+, i.e. ...)
puretube
Quote from: aron topic=103186.msg918473#msg918473
This thread has very little info in it and all from regular posters. It has degraded in quality.
+ another 1 ...
DougH
Quote from: puretube on July 15, 2013, 01:33:48 PM
(B+, i.e. ...)
If that's the case, the circuit is broken as drawn.
Johan
Quote from: DougH on July 15, 2013, 03:44:38 PM
Quote from: DougH on July 15, 2013, 08:58:09 AMI'm still not sure what "POINT B TO POINT B" means on the schematic...
(B+, i.e. ...)
It already was all the time with that high resistance path from power tubes cathodes to ground, but I'm giving Ryan the benefit of a doubt and assume his drawing is showing a concept and not a working amp.
j
Edit.....but benefit if doubt or not, I do think its time for Ryan to give us a soundclip or a pic of his builds or just something more than just big words
DON'T PANIC
Jdansti
Quote from: pinkjimiphoton on July 15, 2013, 12:47:41 PM
+1
0.002 μF = 2nF = 2,000 pF
I'm just trying to understand this statement: 0.002 μF > 0.47 μF.
I'm pretty certain that: 0.002 μF < 0.47 μF
0.002 μF is 235 times smaller than 0.47 μF
2/1000 < 470/1000
If someone offered you a choice between $0.002 million and $0.47 million which would you take (assuming you want the larger pile of cash)?   ;D
lah! thats right, i dont know what i was thinking. majorrrrrrr mixup.   :icon_redface:
The point B to point B means connect point B to point B, point B1 is to the primary tap on your output transformer, it is lead to the B+ primary output from the rectifier.
which of those piles of cash sounds better?
this is an entertaining thread. can't wait for the punchline.
" I will say no more "
Digital Larry
"The fragile harmonics can't survive in a crystal lattice"?
Digital Larry
