SAD512 16 pin circuit examples
Started by armdnrdy, July 19, 2013, 05:39:45 PM
armdnrdy
Does anybody know of a flanger or chorus that uses the older 16 pin version of the SAD512?
I've scoured the net and all I can find are schematics for the SAD512D eight pin version.
If you can clue me into the effect I can look in that direction for the schematic.
I'm doing some research for the low voltage BBD tester and since the SAD1024 and the SAD512 pin arrangement are so close, I was planning to use CMOS switching and a rotary switch to make it possible to use the same Ziff socket for both the 512 and the 1024.
I need to see how the unused pins are dealt with. The data sheet doesn't address those pins and there's no example showing their connection/non connection to ground.
theehman
You could probably use it in any SAD1024A circuit where the 2 sections are paralleled, such as the Electric Mistress.
Ron Neely II
fx schematics and repairs
Fender3D
I think Reticon labeled SAD512 the half working SAD1024...  :icon_twisted:
armdnrdy
#3
Thanks for the replies,
You know....I'm beginning to think that their were no mass produced effect pedals using the SAD512 16 pin version.
I can't find a reference to even one pedal!
I never noticed that before! I don't think that I ever paid attention to the pin count if I saw that an effect schematic listed a SAD512.
Now that I'm looking for an example......they are all SAD512D pin outs!
Can somebody prove me wrong?
cortezthekiller
Although not exactly a "pedal", the Arp Omni 2 synthesizer used 3 of them for their chorus/flange effect.
They were the 16 pin versions.
http://manuals.fdiskc.com/flat/ARP%20Omni-2%20Service%20Manual.pdf
armdnrdy
Thanks for the lead!
I should be able to figure this out now.
