Boss Chorus Ensemble CE-1 burnt Transformer help
Started by richon, August 05, 2013, 09:42:12 AM
richon
Hi,
A friend of mine blew his Chorus Ensemble CE-1
http://3.bp.blogspot.com/-Gql659utqNA/T9sblknZqjI/AAAAAAAABdY/QSO3aAmZJU8/s320/boss_ce-1_chorus_ensemble-785603.jpg
So, after checking everything the transformer shows no output voltage and I can't find any info on how much volts should it give to the PCB
Does someone knows if there's only one version of it?
greetings from Chile
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Govmnt_Lacky
Well...
According to the schematic I found here:
http://www.generalguitargadgets.com/boss/BossCE-1v2.gif
It looks like a step down transformer from 120VAC to a center-tapped secondary that provides 18V-0V-18VAC should do it. They are pretty common so I would think it is just a matter of finding one that fits the voltage, current, and size requirements you desire.
Good Luck  ;D
P.S. Apparently, there are 2 versions of the pedal. Both schematics are on the GGG website!
richon
The transformen has only two output cables ... They get to a dpdt power switch And then to the Pcb ... So i'm a little confused
Richon - Ricardo
Viña del Mar
Chile
www.richon.cl
Govmnt_Lacky
#3
Quote from: richon on August 05, 2013, 10:01:04 AM
As you can see in the schematic, the transformer SHOULD have 3 outputs. 2 of them do go to the DPDT switch (those are your 18VAC outputs)
The 3rd output is the GROUND that is used for the circuit. I do not know how yours is wired up but, the PROPER way would be to follow the schematic and use a center-tapped transformer. I believe the "proper" rating would be 120VAC input and 36VAC output CENTER TAPPED.
EDIT: Some older transformer-based pedals either clipped or did not use the center tap on the secondaires. Instead, they just tied ALL of the ground points together and I believe they went back to the neutral connection of the primary or the Earth connection of the power plug. I would advise going according to the schematic though  :-X
Govmnt_Lacky
