Hey guys need help fast, got a gig tonight!!
Started by JPGraphX, August 30, 2013, 01:07:20 PM
JPGraphX
Hey,
I got a brand new 3pdt for my microamp clone, I got no sound coming out of my pedal. If I check continuity, tip to tip, it is working and sleeve to sleeve working, but no sound coming out. LED is also working on and off..  Please help me I got a gig tonight! Thanks!
double check your wiring on the 3pdt...
pcb in/out...
Ice-9
Try using a multimeter to check the 3PDT switch is working . Is it working in bypass ?
www.stanleyfx.co.uk
JPGraphX
I have double check and wiring seems good..  3pdt working good also
JPGraphX
But no sound in True Bypass, but there is continuity...
Ice-9
sounds silly but have you checked ya guitar leads, if you have continuity on the pedal maybe you have a dodgy lead or a short in the pedal.
www.stanleyfx.co.uk
JPGraphX
JPGraphX
JPGraphX
JPGraphX
I have continuity from tip to sleeve and enclosure, not normal huh?
JPGraphX
JPGraphX
Actually when I drop it in my enclosure, same thing.. Damn, where is that *#&*& short coming from!
Ice-9
Loosen that jack and try and spin it round a bit.
www.stanleyfx.co.uk
JPGraphX
Philippe
check ground continuity...a polarized electrolytic cap that may be facing the wrong way or a cold solder joint. barring sloppy worksmanship, it's usually something minor.
