Gain squeals when opened up all the way on my lovepedal purple plexi 800
Started by HairMetal, August 28, 2013, 10:35:19 PM
HairMetal
If anyone could help it would be great. Whenever I turn the gain pot all the way up on the pedal it squeals.
I got the schematic from here: http://revolutiondeux.blogspot.com/2008/10/lovepimple-purple-pills-lovepedal.html
A guy on the page said he had the same problem and changed the r5 to a 10K and that fixed his but not mine.
pappasmurfsharem
J0K3RX
Quote from: HairMetal on August 28, 2013, 10:35:19 PM
Change R3 to 22 ohms and see if that helps. If it does, you can go higher until the squeal totally disappears...
Other changes but try R3 first.
C1 - 370pF
C2 - 4.7n
C3 - 4.7n
C6 - 100n
C7 - 47n
Then report back or we will hunt you down and eat your brains! :icon_twisted:
HairMetal
Quote from: J0K3RX on August 29, 2013, 02:50:57 AM
C1 - 370pF
C2 - 4.7n
C3 - 4.7n
C6 - 100n
C7 - 47n
Thanks a lot changing r3 worked. I put a 22 in and that helped but there was still a little squeal so I put a10 in after that and that took all of the squeal out.
HairMetal
Okay new problem. I wasn't really paying attention to anything else but once I upped the resistance the pot for the gain doesn't do anything, it just stays at one level.
