madbeanpedals dirtbag deluxe - request quick voltage check
Started by ulysses, September 03, 2013, 12:27:17 AM
ulysses
hey guys
im building the madbeanpedals dirtbag deluxe (EH deluxe memory man). im using a madbean pedals roadrage (charge pump with 1044 chip)
im having trouble with very distorted repeats.
when i check the voltage of the chargepump by itself, it measures 14.75volts using a boss 9v adapter.
when i solder it to the dirtbag deluxe voltage in, it drops to 12.5volts.
is someone able to do a quick check on theirs to see if theirs drops to 12.5 too.
cheers
Scruffie
A 1044 probably doesn't provide enough current, you'd be better off with a LT1054.
Your voltage shouldn't drop that much, no.
ulysses
