OSHPark Share - Sound 2 Light Pedal Lighting Boards
Started by chromesphere, September 09, 2013, 06:59:50 AM
chromesphere
Hey guys,
***unverified
I've been wanting to design something (simple) that you can fab yourself...because you know...I love you all.  This is a blindingly simple pcb.  Its Deadastronauts (Robs) sound2light.  Basically you plug the output of an effect into the input of the board and LED's will flash with the output.  Good for distortions (that don't already have led clipping that flash), delays etc.
The fabbed pcb's are small.  approximately 17mm x 17mm.  If you haven't seen the project that I used the sound to light, here it is:
Depending on the FV of the leds your using you should be able to power 2 to 4 Leds.
There are 2 outputs on my boards so you can power 2 - 4 leds per output.
Link to project:
http://oshpark.com/profiles/diyguitarpedals
IC = LM386
C1 = 10uf
Resistors = 100ohm
I'm going to order a few of these and test it out, until then its unverified.  Figured they would be handy to have a few around.
Hope you like it!
Cheers,
Paul
Pedal Parts Shop                Youtube
chromesphere
Thanks Rob for the circuit.  Hope folks find the boards useful!
Paul
