Rotary Switch Mix
Started by tombaker, September 30, 2013, 01:45:02 AM
tombaker
Howdy,
I'm using a 6x2 Pole Rotary switch to switch between monitor channels on a small 4 channel mixer I want to use as a backup for ENG stuff.
I've got the 4 channels running separate lines to the switch, as shown in the link:
https://www.dropbox.com/sh/7njyart9dvyhsr1/ZkC-qrWvFm/rotary-switc-2-poles-6-lines.png
Is there a way I can wire the switch with the remaining lugs so that I could get a mix of all 4 channels before the signal goes to my headphone amp?
Blue Box, Harmonic Perculator, Brian May Treble Boost, Klon Vero, Fuzz Face Germ/Sili, Echo Base Delay, CS-3 Monte Allums Mod, JLM 1290 Mic Pres, JLM Mono Mic Pres, Engineer's Thumb, A/B/C & A/B boxes, Tiny Giant Amp, Microamp
