Boss s5500g diode / Motarla 1n 5472 ?
Started by JasonG, May 31, 2007, 04:52:43 PM
JasonG
Hi
Got a good deal on  a Metal zone . The last owner used the wrong adapter  the D6 diode exploded! I have subed a Motarla 1N 5472 ( its what I have to work with)  I cant find a data sheet on it. The S5500G is a hi speed switching diode. Will the motarla work?
Class A booster , Dod 250 , Jfet booster, Optical Tremolo, Little Gem 2,  mosfet boost, Super fuzz , ESP stand alone spring reverb red Llama omni-drive , splitter blender ,
NEVER use gorilla glue for guitar repairs! It's Titebond , Elmers, or Superglue
according to this datasheet from knox semicondutors:
http://pdf.datasheetcatalog.com/datasheet/knox/1N5449.pdf
the 1N5472 is an "abrupt varactor" diode, which I think means it's used in tuning tv's et.al. it is a strange choice for use in a pedal. if it is a series protection diode, use a gp schottky diode for its low V drop, if a reverse biased polarity protection diode, any 1 amp rectifier, like savio says, will do an admirable job.
" I will say no more "
