Fuzz FZ1, have I got the wiring correct (image included)
Started by ericohman, May 11, 2009, 08:54:16 PM
smnm
Quote from: arnqvist on June 15, 2009, 12:23:22 PM
But i found that the 470K resistor from the corrected schematic above is stated a 470ohm resistor in the patent.
Is this correct?
470K is used on all actual units I've seen pics of, I think the patent schematic is wrong.
Temperature affects Germanium transistors, that's just a fact of life, changing resistor values will not alter this.
But I don't agree that you need leakage from the resistors for this circuit to work - the 2N270s I used had zero leakage, and it sounds great with the stock values from the corrected schematic.
If your transistors are oscillating they might be too high gain - if it's only when the fuzz/attack pot is on full, I wouldn't worry too much about it if you like the sound at lower levels.
Masuto
*wooosh* magic!
LucifersTrip
always think outside the box
