Apparently every TO-92 BJT I own is backwards?
Started by midwayfair, November 23, 2013, 05:11:03 PM
midwayfair
I was double checking a layout just now and noticed this ... I checked a bunch of dozen different ways, but with the pins facing me, flat side up:
2N5088: Collector on the left (should be on the right)
2N3904: " "
BC549C (Fairchild from Mouser): Collector on the right. (Should be on the left)
Etc.
It's not just a couple things from a few suppliers, it's every single TO-92 I have is backwards according to the datasheets.
Everything I have with an emitter tab is correct, though ...
I find a great many datasheets are rather ambiguous in the way they describe the pinout.  Am I looking at the top of the transistor?  Up from the bottom?  That's why I use my meter to confirm.  I look for a plausible hfe, and let that tell me what pin is what.
midwayfair
Quote from: Mark Hammer on November 23, 2013, 05:33:02 PM
I'm so used to just knowing the pinout of the ones I use all the time that I haven't looked at the datasheets in a long time. That's why I was so surprised when I looked up a 2N5088 and it was backwards from what I expected.
Perhaps you'd like to share how you check them please Jon.
I wouldn't have a clue and I'd appreciate knowing so I can put it in my little book.
midwayfair
Quote from: Kipper4 on November 23, 2013, 05:53:38 PM
Just plug them into a buffer or booster circuit.
akc1973
Using your hfe setting on your DMM is a good way to verify pinouts, I find...especially when it's hard to read which manufacturer's transistor you have.
Builds: Bazz Fuss, Orange Squeezer, Omega, Green Ringer, Dist+, X-Fuzz
All bipolar transistors work with collector and emitter swapped - kind of.
In the reverse mode, Hfe is dramatically reduced.
If you are really befuddled.... in addition to the low Hfe in backward mode, as you go above 7V the Collector junction will stand-up, the emitter junction will break down.
A 24V supply and a 22K resistor in series, and a voltmeter, can tell. Apply the resistored voltage to two pins. Measure the voltage on those pins. If 0.6V, you found a forward junction, flip the leads. If 7V, you found a reverse Base-Emitter junction. If 23.9V, there's a reverse Collector junction in there. Six measurements will find ALL the breakdown voltages, forward and backward.
UKToecutter
I personally use an inexpensive Peak tester (DCA55).
It tells you which leads are which and gives you a full set of specs for your individual device.
The more expensive DCA75 will even draw you graphs!!
You don't want to get caught out by using a datasheet and either a) reading it wrong, or b) using the wrong datasheet
ShumannPLL BOM
Reserve Boards
jon, all those transistors are backwards. only the bc5xx series is correct.
anyway, I always draw the 3d, isometric (?) view on my circuits. still, I have a couple of way old PN3564's, which I would expect to be backwards to start with, except they have a preformed base lead bent towards the flat. so now I don't know what is where, except the base, obviously.
" I will say no more "
midwayfair
PRR, thanks for the testing regimen.
I did some more testing today, and it looks like my confusion arose from the weird biasing network I used in a couple different circuits. I had the base biasing resistor going to +9v instead of the collector. Apparently when you do that, the transistor works better backwards ... I guess I'll redo a bunch of layouts now to fix that.
However, it also looks like my Eagle library might be backwards, too? Here's a layout I did where the schematic part was BC549C, but the collector is flipped.
Yes thanks PPR that's one for the book. And print page. :)
pinkjimiphoton
i told you guys sometimes stuff sounds better backwards. i guess this is why!!!
i don't bother with the data sheets anymore after getting so much stuff wrong, i check everything on my meter to see what's what, and even then, sometimes the reverse beta will sound better, especially with germaniums.
weird planet!!!
Slava Ukraini!
~Jack Darr
> weird biasing network I used in a couple different circuits. I had the base biasing resistor going to +9v instead of the collector. Apparently when you do that, the transistor works better backwards...
No. Both are valid. Optimum resistor values will be different. Some voltage-tests and comparison may bring clarity.
If it "works better" with C and E reversed, it probably isn't much of an Amplifier.
____________________________
Ah. Yes, Ge does not have the trustworthy 7V emitter breakdown, and may not have a low reverse Hfe. Some Ge parts were quite symmetrical.
pinkjimiphoton
very true... particularly nte ones, some of which have the same gain no matter what way ya turn them. ;)
Slava Ukraini!
~Jack Darr
