Replacing an optoisolator with transistor?
Started by charmonder, December 19, 2013, 08:16:40 PM
charmonder
I'm planning on building up a 4ms Stereo Panneur (schematic http://commonsound.org/panneur/pcb2.4.1/schematic.pdf),
I like the design, controls and features, BUT, I have a feeling the LFO waveshaper controls could be a lot more eventful if I could replace the LED/LDR combos with transistors.
I have it on breadboard, so I tried a few shot in the dark attempts, just to see if I could run signal through any transistor and modulate by the voltages that were intended for the LED. A few of them seemed to actually work, (2n3906, and j201), the problem is I couldn't find anything that wouldn't also distort/fuzz up the signal.
I'm willing to do the work to tweak it correctly, I'm just not sure what I need to do though. Can anyone help point me in the right direction? I would appreciate any advice you might have about this! Thanks!
successful transactions with forum members: bcalla, digi2t, and gutsofgold
armdnrdy
You can get the same type of effect as the vactrols with a JFET.
Take a look at the Ibanez ST810 Stereo Pan for ideas.
It's my opinion that vactrols sound more smooth/liquid in a circuit such as this.
