eagle pcb layout with holes
Started by nikosrf, January 27, 2014, 10:12:34 AM
nikosrf
i just finished a pcb layout in EAGLE but the final (eps export) result is without the holes.
So i opened it in Illustrator and i add some white circles for the holes.
How can i export this directly from EAGLE?
https://www.dropbox.com/s/3n3hgditq1pf1t5/ScreenShot%209.png
pappasmurfsharem
Quote from: nikosrf on January 27, 2014, 10:12:34 AM
There should be a "holes" or drill holes layer in eagle was that enabled before export?
nikosrf
there is holes and drill layers but nothing appears
pappasmurfsharem
seems to work fine for me, using madbeans library, and exporting at 600dpi monochrome.
Can't post an image but it works normally not sure what might be causing your issue. I did have to remove the layer Tdocu
nikosrf
found it.
in the CAM processor window, where you export the file, there is a check box "Fill pads" that was checked.
unchecking it the holes come in place!
pappasmurfsharem
Quote from: nikosrf on January 27, 2014, 08:49:14 PM
found it.
Why use a cam?
Eagle can export directly to png
File -> export
diydave
Or print to a pdf-file.
Be shure to check or un-check the according layers (only vias, border & bottom layers - rest is not of any use for a pcb)
