I fried something...
Started by climberboy, January 17, 2014, 01:57:23 PM
climberboy
just to give you guys an update, I replaced that opamp and it works! Thanks everybody. I also had a couple bad wires that I replaced, but the IC was the main problem. Thanks again!
Jdansti
#21
Glad you got it going!  Next time fry some chicken!  ;)
Edit:
BTW- you might want to put a piece of tape or some type of label on the end of your adapter cords near the plug and write the voltage, polarity, and whether it's AC or DC. I've done this to all of mine and it's helped me avoid using the wrong adapter.
AceFrehleyFan
Hello all,
I have owned a GNX3 and I currently own a GNX4 and the PSU is AC and not DC which is most likely why you fried your pedal.
Hope this helps,
Shawn
aron
Now that makes sense! KISS ALIVE!
