Problem with pcb file
Started by jimmyandrex, February 04, 2014, 05:07:47 AM
jimmyandrex
http://homemadefx.web.fc2.com/
Is anybody familiar with the site above. I tried opening the pcb file for the fulldrive mosfet2 but wasn't compatible with ExpressPCB. What program will open the .pcb files offered on this website?
armdnrdy
When you use google translate the Japanese writing states:
PCBE is required in order to view the PCB ● zip file.
Please click here to download the PCBE. → PCBE downloads
please refer to here on how to print the ● PCBE. → How to print PCBE
http://translate.google.com/translate?hl=en&sl=ja&u=http://www.vector.co.jp/soft/winnt/business/se056371.html&prev=/search?q%3DPCBE%26rlz%3D1T4GGHP_enUS450US450
jimmyandrex
Hi - thanks
Yes, I did use the google translate before but the software download is in japanese the instructions are incorrectly displayed so you cannot us the translator to install it
The fulldrive.pcb doesnt appear to be a .pcb or gerber file
I'm wondering if there is any other software which will open it?
It's almost a plain ASCII text file. Some "NAME=" attributes are gibberish to me, probably Japanese in an encoding my plain text editor does not know. The rest is ASCII letters and numbers with fairly obvious meaning.
Perhaps someone will recognize the file syntax and know how it might be modified or force-fed to another application.
pappasmurfsharem
#4
Have you tried these 3 applications?
CADSTAR (Printed Circuit Board Design) by Quadra Solutions
CADSTAR is Zuken's Windows based desktop PCB Design solution, ready-to-use, and easily integrated into your current design environment while preserving your legacy data. The identifying characters used for this association are - Hex: 50 43 42 0D 0A 44 61 74 61 20 53 74 72 75 63 74 75 72 65 20 41 63 63 65 73 73 20 56 65 72 73 69 6F 6E 20 , ASCII: PCB Data Structure Access Version
ExpressPCB (Printed Circuit Board Layout) by ExpressPCB
Free PCB software. This association is classified as CAD/CAM.
Ivex Winboard Design File
PADS (Printed Circuit Board) by Mentor Graphics Corp.
A free browser is available for this file type. This association is classified as Graphic. Related links: Mentor Graphics PCB Browser
This site also has other recommendations http://www.edaboard.com/thread16495.html
armdnrdy
I was able to get all the way to the download point for PCBE_0.58.4_setup.exe from the link I posted above.
The board files are in the PCBE program....so if you want to access them.....download the program.
jimmyandrex
Hi
Since my last posting I downloaded the japanese software and managed to open the file but as the menu was in japanese it was difficult to do what i had intended, which was to at least print out the file in black and white
- armdnrdy did you managed to export the file so it could be read by any english language pcb software. I couldn't find an option for that?
jimmyandrex
I managed to print out the pcb board tracks but they were very wide with very little space between them and no hole guide. Not the usual track and pad arrangement. I think I'll give it a miss.
