1 x PT2399 Reverb
Started by M23Bomber, March 08, 2014, 06:19:13 PM
M23Bomber
Hello All,  :)
I saw the Cave Dweller  at Mad Bean Pedals, is it possible to make a very basic reverb based on this layout?
Did anyone try?
Regards
M.
knutolai
Reverb requires more delay lines. You can get the feeling of a "space" with simple delays, but if you are looking to build something to rival commercial reverb pedals you should look towards the various Belton Brick reverb projects
M23Bomber
Hello Knutolay, thank you for your reply.  :)
My purpose with a single IC reverb (and reverb circuits in general)  is to add it to some of my ongoing distortion pedals projects, to give them  "special space feeling" , that can be turned on immediatly when that particular pedal is activated. So that the audiance can have new level of depth.
By  "special space feeling" I imagine a kind of surround echo  as the one in concrete rooms or large basement filled with people.
QuoteReverb requires more delay lines. You can get the feeling of a "space" with simple delays,
I quote you post and raise a question about it:
Would the original signal and the the one produced by Cave Dweller Reverb( assuming it is possible  :icon_biggrin:) be enough t create a "good" reverbsound?
Regards,
M.
knutolai
QuoteWould the original signal and the the one produced by Cave Dweller Reverb( assuming it is possible  icon_biggrin) be enough t create a "good" reverbsound?
You are describing what the circuit is already producing, so no. Getting really good reverb sounds either requires a DSP chip with a coded reverb algorithm or a network of delay modules with fine-tuned delay times. If you want to keep things simple I would advice you against going down that route.
If you are looking for a cheap way to add a "special space feeling" a delay circuit can do the job. Basically you could put together the cave dweller or a similarly simple pt2399 delay circuit, set the delay time low (around 4.7k resistance from pin 6 to ground) and change around the filtering for brighter repeats. Kinda gives a sound that you might associate with uncomfortable underground spaces.
Have a look at this thread: http://www.diystompboxes.com/smfforum/index.php?topic=88178.0
The "Sewer Pipes Ring-Verb" might just be what you are looking for.
M23Bomber
Hello again :)
Yes,the purpose is to keep the garage band and pub gig  in some of my distortiotion pedals, not making the best reverb pedal ever  ;)
I appreciate the link it has another diagram to analyze and experiment till I get the sound I want.
Regards, M
M23Bomber
Hello knutolai  :)
FYI
I found an IC that will privide reverb, the ES56033E by ERSO, and the schematics have low part counts. I will experiment with this one untill the sound I want is obtained.
Regards,
M.
It won't be reverb, by any stretch, but more low pass filtering on the delay and added low pass filtering on the regen will yield something that moves more in the direction of reverb.  Whether that does what you need is up to you.
merlinb
I wonder if envelope control of the delay time could be made to simulate reverb? In other words, the delay is fairly long when the note is first plucked, simulating the early reflection, then the delay time is quickly reduced, creating a rapid collections of late arrivals...
armdnrdy
Quote from: M23Bomber on March 09, 2014, 08:11:55 AM
FYI
I found a sound sample of a preamp/reverb/delay on youtube. (below) A guitar sample is featured toward the end of the video.
It is my opinion that this IC does not produce a very good reverb. It sounds like a fast slap back echo at best.
I agree with knutolai's comments about more than on delay to create a "good" reverb.
So far.....one of the best modules to come out that feature a more than acceptable reverb are the Belton bricks.
The brick's design incorporates three delay lines to achieve this.
kingswayguitar
samhay
Quote from: merlinb on March 09, 2014, 02:58:43 PM
Whether it sounds like reverb or not, this is an interesting idea for an effect. A FET as a variable delay resistor should be fairly easy to implement.
psychedelicfish
You'd have to keep the pitch constant as you change the delay time, which could be difficult. Could you do it with PWM? If you had a nice sharp square wave changing the delay time you wouldn't have much audible pitch shift...
If at first you don't succeed... use bigger transistors!
Quote from: psychedelicfish on March 09, 2014, 06:51:14 PM
The pitch would change.  Whether one is doing it in the anaog or digital domain, changing the sample rate quickly WILL produce audible pitch shift, similar to the Digitech Whammy pedal.  I'm not saying it would be uninteresting, but it wouldn't be reverb, that's for sure.
Again, I recommend at least trying my earlier suggestion of making the lowpass filtering a little heavier in both the main delay path and the feedback path.  So, instead of 100nf caps for filtering, use 120nf or maybe a pair of 150nf.
Keep in mind that part of what MAKES reverb reverb is that it sits way in the back of the dry/wet mix, and the fact that it lacks much top end is part of how it does that.  If one arranges to trim a little more top-end off the feedback signal with each iteration, that also lets you turn the feedback up more, without the sound getting too cluttered.
Lurco
#13
Wouldn`t that pitch-up?
edit: ooops-seemed to have missed those posts above that already mentioned that.
M23Bomber
Hello All,
This circuit has the following schematic:
http://construyasuvideorockola.com/downloads/reverb.pdf
Here is a call to patience and breadboards to develop this preamp with reverb and delay  into a great pedal !!!!
But the PDF is in Spanish :icon_biggrin:
Regards,
M.
midwayfair
Quote from: samhay on March 09, 2014, 06:23:05 PM
Skreddy's delay does it with an LED and LDR.
I keep meaning to just build something like that, but I just don't need another PT2399 delay.
pinkjimiphoton
#16
Quote from: kingswayguitar on March 09, 2014, 03:58:51 PM
sounds like a pt2399
hmmmm..... wonder if it has the same lock up kinda issues as a 2399?
http://www.cbtricks.com/radios/galaxy/datasheets/ic/pdf/es56033.pdf
Slava Ukraini!
~Jack Darr
pinkjimiphoton
did anyone ever figure out what the delay time is with the ES56033E? if they'll combine shipping, i'm gonna pick up 2 of those and 2 ES56028E chips to experiment with... hoping they can maybe be adapted to the little angel chorus. be nice to not have to deal with latchups..
Slava Ukraini!
~Jack Darr
