First time using DIYLC - Headphone amp
Started by caspercody, April 28, 2014, 02:40:52 PM
caspercody
I used DIYLC for the first time to create this:
http://www.vellemanusa.com/downloads/0/illustrated/illustrated_assembly_manual_k4102_rev1.pdf
I am using version 3.28.0, and I have some questions?
When I put a trace cut (the red square with the red circle) on the board this icon does not show up. It does cut the trace.
How do you get it to plot just showing the board, and trace cuts?
Rob
samhay
^When I put a trace cut (the red square with the red circle) on the board this icon does not show up. It does cut the trace.
Double click on the cut and un-tick 'Cut between holes'
^How do you get it to plot just showing the board, and trace cuts?
I don't know if there is an easy way. I copy and paste everything then delete components.
pappasmurfsharem
Quote from: samhay on April 28, 2014, 05:10:10 PM
I use the OLD version now because I like the way it looks better, but there is a way to select all of a specific componet. (I believe double clicking the component in the top bar) Then pasting that over a copy of the board.
caspercody
Thanks for the replies!!
I do not know how to copy, or attach the file to posts, but if someone else could I could email them the information. If anyone wants to use it? Or review it.
