synchronize 2 LT1054s?
Started by jdub, June 10, 2014, 02:25:03 PM
jdub
Has anyone ever tried to synchronize the clocks of 2 LT1054s? Couldn't find anything here or on the webs...sent a request to TI support and haven't gotten a reply.  Datasheet tells how to synchronize one 1054 to an external clock, but I'm unclear as to how to sync with another 1054.  I'm fiddling with a power supply circuit where one is used as a doubler and another as an inverter, and I'm getting what I believe is heterodyning between the two ICs.  Suggestions?
A boy has never wept nor dashed a thousand kim
armdnrdy
There are a few data sheets running around out there for the 1054. Some are better than others for application info.
I don't know if you have this one: http://www.jameco.com/Jameco/Products/ProdDS/1351849.pdf
Make an external clock to drive both of them. A couple of CMOS gates, or a clock chip from an old BBD, maybe a CMOS 555 even.
samhay
^one is used as a doubler and another as an inverter
Or depending on how much current you need, use one charge pump to do both at the same time.
jdub
@Larry: Thanks, I noticed that...already have that one, though  :)
@samhay: Yeah, I need the extra current provided by the dual setup...tried the other way, but IIRC, using one chip for both functions yields ~25mA, I need around 40mA...
@RG: I was so focused on synching one 1054 to the other, that I didn't even think of this, the simplest solution...doh!  See, RG, that's why you make the big bucks  :D
Just out of curiosity, though, do you know if it's possible to synch one to the other?  I couldn't suss out which pin you would take the clock signal from on the 1054, or if you even can...
Govmnt_Lacky
Quote from: jdub on June 10, 2014, 02:25:03 PM
The LT1054 is also made by Linear.
Try them... they may be a bit more receptive and helpful  :icon_mrgreen:
