Sans Amp GT2 rotary switch
Started by adamskyyy, May 30, 2014, 06:34:33 PM
adamskyyy
In diagram of sans amp from tonepad website I should use DP3T switch. Does anybody know what kind of rotary switch instead of DP3T can I use?
Here is an example http://www.adpost.com/ph/musical_instruments/2519/
armdnrdy
You can use a 4 pole, 3 position rotary switch. Two of the poles of each switch are not connected. Instant 2 pole, 3 position rotary switch.
Here's an inexpensive 4P3T but it has PC mount pins. You can use this by soldering wires to the pins, or make a small daughter board with wire pads.
http://www.taydaelectronics.com/rotary-switch-4-pole-3-position-alpha-sr2612f.html?gclid=COjgjIrv1L4CFZFufgodx08AHA
adamskyyy
Thank You, I've just bought this switches. I will raport You about my results soon.
