Advice needed for re-wiring a SHO circuit.
Started by Snufkinoob, May 31, 2014, 05:35:46 PM
Snufkinoob
A friend of mine made a SHO boost circuit that I'm going to rehouse, but I've not done much soldering or wiring (just guitar pickups) and no next to nothing about electronics, so I need some advice on attempting some alterations.
I want to remove the battery snap, LED, and the most problematic; replace the foot switch with a toggle switch
Here's the wiring diagram of the circuit I have: http://diy.musikding.de/wp-content/uploads/2013/06/hardonewire.pdf
Is it possible to have a toggle? and how do I rewire the circuit to take out the battery and LED?
EDIT: Apparently I just need a DPDT on-on switch? (With 6 connectors like the foot switch?) - if so, how would I wire it up?
Mustachio
"Hhhhhhhnnnnnnnnnnnnngggggggg"
Snufkinoob
Hi, I managed to sort it out before reading your reply, but thanks for the links, I'm sure they'll turn out to be useful.
Here's the finished SHO...
