Guyatone Fuzz Monster dissection.
Started by digi2t, May 19, 2014, 11:50:35 PM
digi2t
Hey folks!
Andy and I have been working on the Guyatone Fuzz Monster. I did a thread on some of the Guyatone FLIP series pedals a few weeks back, and one by one, we'll dissect them, and post the traces as we go. I have a Fuzz Monster, and Hell Monster on hand, and a Funky Box on the way from Japan. I'll be cracking them open as we go down this FLIP'd journey (pardon the pun  :icon_mrgreen:).
For now, here is the schematic, courtesy of UKToecutter (Andy);
Please note that the power section has been modified for AC power. Normally, these pedals use a 12VDC wall wart, but I found that even the Guyatone branded wall warts are noisy, especially at high fuzz levels. They are crap, but, by adding a AC to DC scheme directly to a potential clone PCB (see For Sale/Trade section), the noise can be pretty well killed. As for the balance of the schematic, I've gone over it with a fine tooth comb, and it matches the unit.
Go forth, and profuzzinate. :icon_cool:
Dead End FX
http://www.deadendfx.com/
Asian Icemen rise again...
Gus
Looks like most of the distortion is from the JFETS to the LED clippers.  You might need to select them I would not adjust the drain resistors I would adjust the source resistors. I still don't understand why people still adjust drain resistor it changes the output resistance.
I don't think the double caps make a difference used for coupling around the JFET section.  This is a distortion and I don't think it matter even with home audio.
Does it have a tube in it just to be a "tube" effect?  I wonder how much the sound would change if you connected the clipping LED section to the opamp and removed the tube.
bool
Am I seeing a "clever circuit" that modulates the operating point of a first fet with the source voltage of another (probably modulated by the audio signal)? Quadrants C1, C2..
The part in C5/C6 had me bamboozled there for a bit until I realized it was a plain vanilla op-amp gyrator circuit.  The way you have the Vref connections is a little confusing.  Maybe have R5 and R15 (100k@) pointing downward so that they are in a more familiar format.
But diligent work!
digi2t
There is a correction to be made as well; Q7 is an NPN transistor, and not a fet. I'm just so tied up with the Resonator right now, that I haven't had time to update it.
Dead End FX
digi2t
PCB's are now for sale in the buy/sell section.
Dead End FX
