Super simple NPN transistor curve tracer
Started by merlinb, July 23, 2024, 07:56:23 AM
merlinb
I found a circuit many years ago in a back issue of Elektor for making a super simple curver tracer for NPN transistors. I finally rediscovered it today and thought it deserves to be shared. It's extremely clever, I wish I'd thought of it!
https://www.eddybergman.com/2017/06/simple-but-effective-transistor-curve.html
https://archive.org/details/ElektorMagazine/Elektor%5Bnonlinear.ir%5D%201980-09/page/n37/mode/2up
jorg777
What are those mysterious part numbers "TUT" "TUP" "TUN" "DUG"?
How can ground drive the X axis?
What is that upside-down "T" marking on the middle of the three outputs?
GibsonGM
#2
Thanks, Merlin!
Abbreviations are TUN = "transistor universal NPN"   TUP = "transistor universal PNP"
DUG = "diode universal germanium"
I take that as 'general purpose' transistors
TUT....'transistor under test'?
I don't know what the 'upside down T' is, maybe in the article?
[ulr]https://www.learningelectronics.net/VA3AVR/circ/tuptun/tuptun.htm[/url]
Kevin Mitchell
#3
Quote from: jorg777 on July 23, 2024, 10:24:51 AMWhat are those mysterious part numbers "TUT" "TUP" "TUN" "DUG"?
TUT = Transistor Under Test
TUP = Transistor Universal PNP
TUN = Transistor Universal NPN
DUG = Diode Universal Germanium
I assumed the upside-down T was a reference for a ground point for the scope.
edit:
Mike wins.
GibsonGM
I did (for once) READ THE ARTICLE Merlin linked to first, LOL.  The Bergman article describes building and using this, and gives definitions  ;)
Kevin Mitchell
Instructions are for nerds! For that, my IKEA furniture is inside-out on the first go.
Being used to seeing "DUT" I was able to manage. Though I was stumped on "DUG". Was not expecting a germanium there.
Tempted on breadboarding this. Wondering if that diode can be swapped with a fast switching signal diode (1N914, 1N4148). If not, would a typical 1N34A suffice?
jorg777
Quote from: Kevin Mitchell on July 23, 2024, 10:36:10 AM
edit:
Mike wins.
Ah, thanks.  I went and read the article.  I think it relies on your scope having inputs which are isolated from each other (they don't share a ground).  I'm not sure all scopes are that way.
I liked WLIP's idea to use a true triangle generator made of op amps to eliminate the retrace.
GibsonGM
Quote from: Kevin Mitchell on July 23, 2024, 11:09:31 AMTempted on breadboarding this. Wondering if that diode can be swapped with a fast switching signal diode (1N914, 1N4148). If not, would a typical 1N34A suffice?
Got a Schottky?
Quote from: jorg777 on July 23, 2024, 02:26:09 PMyour scope having inputs which are isolated from each other (they don't share a ground).  I'm not sure all scopes are that way.
No; it does depend on a "floating" 6V supply. Maybe a battery? I just checked: the 'lantern' battery is still available at around five bucks. (There are bigger smaller more-exotic types at higher prices but why pay more?)
merlinb
#9
You can use a Schottky diode instead of the germanium, and it also works fine with a 9V battery (and beyond).
