new oscilloscope help
Started by LightSoundGeometry, November 17, 2015, 05:57:16 PM
LightSoundGeometry
The oscilloscope is new to me, I have only one introductory lab so far and that was with a function  generator. Basically to get to know the knobs and switches etc.
I made a short video - any advice or help is greatly appreciated
LightSoundGeometry
I need a function generator..figured it out lol
deth502
you are an antenna. what you get when you touch the probe is a 60hz signal from the electricity all around you.
"im on dc because im testing a dc circuit" no. "ac" is ac coupled, so any dc component ot the signal being measured will be ignored. "dc" is dc coupled, so the waveform on the screen will include any dc offset.
at this point, you should be concentrating on the trigger level, time base (sec/div), and amplituude (v/div).
the "flashing" is the beam traveling across the screen. it does that on EVERY setting, but through persistence of vision, at a certain speed is appears as a solid line.
GibsonGM
"Visual analyser" is freeware, and contains an audio-frequency function generator you can output from your sound card...or make a quick 555 astable circuit to see square waves. There should be a calibration port on that, too, that will give you a square wave of known voltage/freq....is there a manual?  If not, get one online!
Be cautious, LSG...if you input too large a signal on too low a range, you may pop an internal component, making it necessary to disassemble the unit to find it.  That can be interesting (many pins!!!).   Avoid that at all costs.    This is where the manual is helpful....you'll find those slow settings, where you watch the beam like a heart monitor, are not that useful ;)
Before you try the popular hands-on "push buttons until things work" approach, I would second the recommendation to read the manual. I found the manual for the LS8022 with a quick google search and it's a very manageable 28 pages. Good luck ;D Once you get the hang of them oscilloscopes are a remarkably useful tool, and knowing how to use one to debug a circuit is a very desirable skill.
http://assets.tequipment.net/assets/1/26/Documents/LS8050_manual.pdf
Congrats on getting an Oscope LSG.
Very useful for comparison of input signal to outputs signal peak to peak voltages and seeing exactly what your circuit is doing to the signal vis a vis clipping for example. Symmetrical clipping,Asymmetrical clipping.
Also for DC voltages.
There are many good videos on tricks and things on you tube too.
A manual is a must then you will know the scopes limitations too.
I made some homemade probes using those little clip on things, can't remember what they're called. As well as the ones I bought for it. Mines a 20hz-20khz scope.
I don't use it very often but I wouldn't be without it.
Have fun.
Rich
Edit
Mini grabbers apparently:)
http://www.ebay.co.uk/itm/HT321-18pcs-lot-mini-grabber-SMD-IC-test-hook-clip-jumper-probe-5-colors-/131637566817?hash=item1ea635dd61:g:qYgAAOSwqu9VEVeX
Not affiliated just so you know what I'm talking about
LightSoundGeometry
right on, got the PDF docs on the DL
anybody have any opinions on the cheap chinese FG  you see on ebay for 20 bucks or so? the youtube reviews are a mixed bag of good and bad. I might try that freeware program.
thanks guys
Here's an idea LSG
Build one.
RG Keens quick and dirty oscillator is a good place to start.
Also Sam Hay  has a good one too. I'll have a gander,see if I can find it.
Both are low parts and always handy to have when testing and probing circuits.
Edit
My mistake it was Merlin Bs
GibsonGM
I use RG's Q&D all the time.  A really nice build would be the generator that Merlin came up with, over at his "Valve Wizard" site!  I want to put that together when I have time.
I have both the Q n D and Merlins in the same box.
Switchable so I can choose which one is output.
LightSoundGeometry
oh wow..Time to burn me a kipper and get prepared to start a new project  8) :icon_mrgreen:
No no no no no don't burn it. Smoke it real slow. So you get a good depth and flavour, then savour that satisfying taste.
Scramble some eggs and toast a wedge of bread baste with butter. No nam by lambs margarine mind.
NOW you got it.
Breakfast kippers.
Quote from: LightSoundGeometry on November 18, 2015, 04:56:27 PM
I have a Chinese function generator I got from eBay for around $60, and I haven't found anything to complain about yet. Testing it with my oscilloscope has shown that it's accurate (either that or they are both off by exactly the same amount :P ). I looked into building one, but using the ones at school made me want a relatively nice one with a lot of functionality. But how much you spend on it should definitely be proportional to much you really think you'll use it. If it's just going to be an occasional thing and just for testing pedal functionality, I would highly recommend the Quick and Dirty.
Skimmed my eBay history and found the one I bought:
http://www.ebay.com/itm/291250697392?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
