Shelving EQ variable frequency
Started by PBE6, June 01, 2016, 10:00:02 AM
PBE6
Does anyone have a schematic for either a shelving or Baxandall-type EQ that allows one to vary the frequency using a potentiometer but keep the gain (relatively) constant? I'd prefer not to switch capacitors in and out if possible.
Sent from my iPhone using Tapatalk
samhay
You have to vary the gain somewhere or else it won't be a filter, so I suppose you mean the gain of the shelf?
High pass or low pass?
merlinb
#2
Do you mean a parametric version of Baxandall? Simplest way is to use a James stack instead, but make R3 variable:
Here's a simple-ish active parametric control:
http://research.microsoft.com/pubs/102099/Malvar_ParmEq_ElMag0381.pdf
(Malver, Electronics, Mar 10, 1981)
PBE6
Yes, I should have been more clear. This will be for a pre-clipping bass cut control. I'd like the gain of both the shelf (lows) and the passband (highs) to remain relatively constant while sweeping through cutoff frequencies using a potentiometer. May or may not be possible without switching the capacitors, but hopefully there is a solution.
PBE6
Great!! Thanks merlinb! I will check this out.
PBE6
Now that I know what I'm looking for, I found a version of the James that uses 2 caps instead of 4 (see Fig.3):
http://sound.westhost.com/articles/eq.htm#s4
I will try implementing this with fixed resistors and adding a 1M pot in series with the 2k2 resistor (R3).
robthequiet
Somewhere on Rod Elliot's site is also a variable frequency shelving EQ that is very constant across the sweep. Something like Variable High-Pass And Low-Pass Filters It's probably more complicated than you might like in a stompbox but looks like it might produce a good result.
lion
Quote from: PBE6 on June 01, 2016, 02:00:17 PM
I'd be interested in your progress.
Erik
FiveseveN
Here's my first thought: RC high-pass with variable R give you control of cutoff frequency (variable v in the sim). Mixing back the original signal gives you "gain" control (variable w). Of course in the real world you need to mind the impedances, maybe buffer a branch or both.
Brisance
you cant just mix a filtered signal with the original, it will be out of phase
FiveseveN
Well it's a starting point that's easy to try out.
But on the subject of pre-clipping high-pass, I've tested a lot of variations and settled on a simple RC filter with variable frequency. The Tim(my) design is also useful. But I'm interested in high-gain; for cleaner sounds, more control might be better.
PBE6
Welp, I finally got around to building this. Interesting, but not earth shattering. I'll post some sound clips later tonight if I can.
