New to working with transformers, simple help
Started by orangecountylumbertruck, December 31, 2015, 10:41:46 AM
Hey Everyone, I'm working off this schematic for my spring reverb tank:
http://gaussmarkov.net/layouts/springrev/springrev-schem.png
My question is in regards to the input of the tank itself.  Do the pins for 4 & 6 from the transformer both go to the input of the tank?  I get that the output from the tank goes to C11 and ground, but I was assuming there would be a single input to the tank, as well as a ground, and it looks to me like both 4 & 6 go "to the tank".  First time working with transformers, hopefully someone can help.  Thanks!
OCLumbertruck
mth5044
Correct, it connects to both sides. Looks to me like you need a tank that has an isolated I nput and grounded output. With the common accutronics numbering system, your fifth digit in the code needs to be C. Check out the chart on this page: https://www.amplifiedparts.com/tech_corner/accutronics_products_and_specifications
Awesome, I'm still waiting for my tank to get here (ordered a 4AB3C1C so I should be good).  The other tank I have here on hand is a Type 247 OC Electronics, which appears to not have the isolated input, it has an input and ground, which is what had me questioning.
Thanks so much for the help!
> Looks to me like you need a tank that has an isolated Input
No.
Because the transformer secondary "floats", it may be grounded anywhere. This can be (would be) the grounded RCA jack on the tank.
Ah-ha, so pin 4 goes to ground, as with the shielded / ground wire on the input.
mth5044
Thanks for the correction, PRR. Are the figures 5 and 6 isolated inputs in this ESP post?
http://sound.westhost.com/articles/reverb.htm
> this ESP post?
Yes.
There's no floating transformer. Rod is taking the current *through* the coil as a correction signal. There are other ways to do this, but (on paper) it is easiest to just take the return current through a small resistor to get a voltage proportional to current. There are ways to sense the current in the "hot leg" but they are more complicated a prone to needing matched resistors or added amps.
Im struggling with this circuit and I think it has to do with the transfomer...maybe.  I swapped out for a 42TU013 via smallbear.  I get dry signal, and I have biased the input and reverb trim pots to 6v, but I still get no reverb.  If I thump the spring tank *hard* i can hear some clanging, but not even as much as I would expect.  The clipping circuit is working, if I slam on the guitar, the leds flicker and the sound cuts out for a moment.  So with a 4AB3C1C tank, and that transformer, ping 4 on the transfomer should go to ground, as should the shielding on the input of the tank, then pin 6 should connect to the input of the tank correct?  And I am assuming the P on the side of the transformer indicates thats the primary side, with pins 1-3?
mth5044
Quote from: PRR on January 01, 2016, 12:19:46 AM
> this ESP post?
Yes.
I see! Thanks!
The Univox U65RN is an amplifier with tremolo and spring reverb incorporated:
You don't need precise impedance matching - it just has to be good enough to deliver adequate signal.  I have a U65G that uses the same schematic.
So I was able to trace the signal and I can hear the reverb off the tank, and even louder after the reverb amp stage at Q2.  The reverb tone gets lost in the mix round R5 & R25.  It seems like If I crank the input to hear the reverb at a decent level, it starts clipping.  Any thoughts on that, or additional ideas on driving the reverb stage / spring harder?  The reverb is there, but very very subtle, even with the matched transformer (42TU013).
Then Q3 stage has a problem.
And Q3 stage doesn't even do much.
Take signal from R5 R25 junction right to your guitar amp. Does that play?
Yeah it plays, but definitely the volume from R5 is much, much louder than R25.
Vitrolin
a small note on the isolated or grounded input/output:
the difference lies in whether the Phono connector ground is connected to the tank itself.
its a small wire that can be removed if isolated is needed.
that's the way it looks in the ones i have lying around, anyway...
#16
Like these:
Input:
Output:
Where the output looks like there is an additional jumper....
Vitrolin
yes
on first pic add some solder and you will have a grounded connector, second pic remove solder jumper for a isolated connector.
So probably total noob question but : Is that required for the circuit I had posted?
Vitrolin
what you posted is isolated input and grounded output
the point was if you have wrong connector its very easy to change this
