Klon Buffer with higher input impedance
Started by exabrial, February 01, 2016, 12:15:43 PM
exabrial
Hey guys,
I'd like to build this buffer to go inside my acoustic guitar to buffer the piezo. I'm reading that 1mohm _may_ not be enough for a piezo pickup. To up in the input impedance, do I merely change out R1 (1mohm) for a 5mohm resistor? Two questions:
Will the vref voltage need to be adjusted due to the increased voltage drop?
C1 looks like a DC blocking capacitor, does it's value need to be changed however?
Thank you!
Refs:
https://manticorefx.wordpress.com/2015/10/29/klon-buffers-theyre-all-wrong
PBE6
Yes, you can just increase the value of R1 to 5M. No other changes are necessary.
That drawing has the pins of the unused half of the opamp floating, this is a bad idea, if you build it connect pins 6 and 7 together and connect pin 5 to 4.5 Volts.
Frank_NH
#4
...or use a TL071... :D
Here's a vero layout:
http://tagboardeffects.blogspot.com/2011/04/klon-buffer.html
ashcat_lt
Quote from: exabrial on February 01, 2016, 12:15:43 PM
Two questions:
But you've actually got 3.  ;)
QuoteTo up in the input impedance, do I merely change out R1 (1mohm) for a 5mohm resistor?
Yep.
QuoteWill the vref voltage need to be adjusted due to the increased voltage drop?
Not with a TL07x or most JFET opamps because its impedance is a whole lot bigger than 5M.
QuoteC1 looks like a DC blocking capacitor, does it's value need to be changed however?
A bigger R will make the cutoff of the filter lower.  It probably doesn't touch guitar frequencies already, but...
More importantly, WTF is going on in the lower right corner there?  A non-inverting opamp section unbiased at the input, open loop (infinite gain) and 100% (unity) positive feedback?  That's got to be a huge mess.  It makes a bit more sense if the + and - inputs are reversed, but not a whole lot.
Thank you!
Refs:
[/quote]
