Noisy Deep Blue Delay Pedal
Started by NBguitarist, November 24, 2013, 04:22:26 AM
NBguitarist
Hey guys so I have built a Deep Blue Delay Pedal according to the following layout.
http://blogs.yahoo.co.jp/cohzyyy/3179497.html
The pedal works beautifully except there are some noise.
There are two type of noise, one is the white noise 'Zzz...' sound when the guitar is not be playing
while another noise is the hiss sound come with the tail of each echo.
Can some one please tell me if the Deep Blue Delay perform like this?
Many thanks.
Jopn
Quote from: NBguitarist on November 24, 2013, 04:22:26 AM
Many thanks.
No, the Deep Blue Delay shouldn't perform like that.  Something is wrong with your build.  For troubleshooting help, please check the sticky on what type of steps/info you should be doing.
nocentelli
I'm not so sure. The repeats do start to get some digital noise on the decay as the delay time is increased. This can be tamed by upping the value of the LPF caps on the repeats path to remove even more high end from the delays and slightly mask the noise. The "white noise" when no signal is present may be improved by increasing the power supply filtering. I also noticed my stock DBD was easily over driven by hot humbuckers played hard: I reduced the input gain, and altered the output opamp gain to compensate.
NBguitarist
Quote from: nocentelli on November 24, 2013, 08:18:44 AM
I do aggree that the noise on the tail of each echo is generated by the chip snice I heard someone also have this problem.
I originally want to ask how to make the echo brighter since I don't like dark analog echo but seem this will increase the noise.
By the way how to I improve the power filtering (I later find that battery will generate less white noise)?
nocentelli
My schematic has a 33r from the +9v supply to a 100uF filtering cap to ground. The +5v from the regulator and the +4.5v from the 10k/10k voltage divider also both have 47uF caps. This is already a fair amount of filtering.
Do you have that in place? I'm less convinced that it is a power supply problem looking at that layout, although if it's not a problem/not so much of a problem with a battery, that does seem to point in that direction. You could try increasing all the values in the power filtering (i.e. 100r instead of 33r, 220uF instead of 100uF, 100uF in place of 47uF caps) which might help if your power supply has not filtering itself.
Renegadrian
Built my third DBD and while the first two acted perfectly, this last one has a constant hiss that makes it unusable...any hint before I dismantle it and put a rebote 2 at its place!^?
GiovannyS10
You already make the measures on 2399? Are you sure your battery is charged? I had a similar problem with my Rebote 2.5, the problem was two:
1. The capacitor on pin 9
2. Low battery.
Change your battery, re solder the C9 capacitor. (Yes, i dont know why, but all my builds with 2399 had a problem with this capacitor.) If it not works, show your voltage measures on 2399. :) We will help you.
Good day!
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
www.instagram.com/allecto
Renegadrian
#7
Got the same noise both from a decent wall wart and a battery (that reads 8V)
I read the voltages in another post, they were similar. FWIW here are mine right now
V from WW 8.9V
4558
1  4.45V
2  4.47V
3  4.45V
4  0
5  4.45V
6  4.47V
7  4.47V
8  8.9V
2399
1  4.97V
2  2.63V
3  0.30V
4  0V
5  2.85V
6  2.64V
7  1.20V
8  1.27V
9  <-> 16 2.64V
thank you for your reply!
GiovannyS10
Okay... I will check my values here and talk you latter :) Don't worry! It's gonna be okay!  :icon_mrgreen:
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
adriano - is your pin 3 on the pt2399 really not 0.00V, or at least 0V like pin 4?
are you feeling queezy yet? it's a good time to sell!
Renegadrian
#10
yep that was very strange, it should be ground, so after your post I checked it again and realized I didn't connect the two traces (3 and 4) together. now they are connected and needless to say it works perfectly.
thx for taking the time to help me!!!  :icon_wink:
Elijah-Baley
Things like those sometime happen. ;)
Quote from: Elijah-Baley on February 03, 2016, 06:27:48 AM
and sometimes, you just get lucky. if only all the fixxes were as quick/easy/painless.
GiovannyS10
Hey dude, sorry for the delay, i was too much busy with personal problems here. But check your pins 7 and 8 we have a discrepancy of more or less 1 volt. You have more than me. Maybe it can be making your noise. Check your pin 3 too. Its need total 0 volts. Its can make something go wrong with your build too.
Try it, and let me know if works!  8)
That's all, Folks!
"Are you on drugs?"
-ARSE, Duck.
