What are you favorite small/simple circuits?
Started by fatmoocow, February 24, 2016, 03:58:18 PM
fatmoocow
I'd like to do a few 1590a boxes with easy circuits that are well documented (vero boards).  Is there anything you really like that's compact and not too complicated.
blackieNYC
Well documented veros for 1590a? Sounds like that would be rather limiting.  If you could work from a schematic I think you would greatly increase the breadth of possibilities. Ever try? From schematic to breadboard? Not as hard as people seem to think.
Loving the DAM meathead, Thing Modulator, Jawari,
PBE6
A simple non-inverting opamp boost is always nice to have, and does double-duty as a buffer if the gain is turned down to 1x. With minor modifications you could add a switch that adds or removes some clipping diodes to make it a triple-duty box.
I also like my "magic box", essentially just a rotary switch that connects different grounded capacitors in parallel to the signal path to simulate the effect of higher capacitance cables. I use it on my bass all the time, and it's passive (and reversible!).  It should work well for guitar too. Try starting with 100pF to make a 6ft cable sound like a 10ft cable, and work up in steps to 22nF or so. You can also add a grounded pot wired as a variable resistor, either 500k in series with the capacitor to turn it into an external tone control or 1M in parallel to adjust the resonant peak height.
A one-knob fuzz would a good choice too.
di_rocks
COT50 and Earthquaker speaker cranker are very good preamp/distortions
EA tremolo and orange squeezer compressor is algo very good and simple
fatmoocow
I can go from a circuit diagram if it's pretty simple, but it takes me a lot of time to figure out what's going on.
Keep the suggestions coming.
GibsonGM
LPB-2.   Try doing one on perf, before long you won't feel limited anymore  ;)
Gargaman
I'm learning on the small ones and all of them I favorite.
I like Fuzzite a lot.
"My profile pic was stolen!"
fatmoocow
Green ringer is on my list for sure.  Already have the parts on their way.  Thx
CD4049.
:icon_wink:
Next is probably the entire PIC16Fxxx series.
Cozybuilder
akc1973
Quote from: fatmoocow on February 24, 2016, 03:58:18 PM
The ROG Omega is my favorite! You won't be disappointed  :D
Builds: Bazz Fuss, Orange Squeezer, Omega, Green Ringer, Dist+, X-Fuzz
Jdansti
My votes: ROG Omega, ROG Pepper Mill, Joe Davisson's EZ-250 overdrive.  Did all these with my own vero layouts.
Transmogrifox
Bearhug compressor
Elektra Distortion
Any Fuzz Face variant
Son of Screamer probably easy fit: http://www.muzique.com/tech/scream.htm but might need to limit number of knobs.
trans·mog·ri·fy
Escobedo!!!!!!
AMZ mosfet boost, like an aphrodisiac for your guitar and tube amp, especially when you play "clean".
the single transistor phase shift oscillator. you can even connect it to things.
" I will say no more "
Groovenut
You've got to love obsolete technology.....
