SRV Special has weird signal
Started by maurice, May 14, 2016, 07:42:14 PM
maurice
I built an SRV Special (tube screamer clone) two years ago using this layout (http://www.newtone-online.nl/forum/index.php?action=dlattach;topic=2562.0;attach=2272;image)
It used to work but I haven't used it for a while, now it has a weird, broken digital distortion - From what I remember the problem used to occur at low volumes with the pedal activated, not it's constant.  Here's a sound file of the clean, then activated pedal (https://soundcloud.com/user485777105/srv-special-clean-then-effect-problem).
Anyone have any ideas what could be causing this?  Can attach images of the board and pedal if required.
Thanks folks!
intripped
Check voltages, expecially Vref
Use a probe to isolate the problem
If the trannies are socketed check if they are well inserted
tranceracer
Also, try rotating the pots 20-30 times to clean. My friend had an old fender solid state amp that made a similar noise and I had to rotate some of his pots almost 100 times before the scratching stopped.
maurice
I was getting no-where with this so I rebuilt it from scratch.  BUT the new board has exactly the same problem :(
I poked around with an audio probe but things just got confusing as the clean signal reaches a few sections but I get lost pretty quick with whatever is supposed to happen.
Here's the voltages:
9v in      9.08v
Q1
C      9.09v
B      2.33v
E      1.3v
Q2
E      2.94v
B      3.51v
C      9.08
IC1
1      1.84v
2      1.84v
3      1.84v
4      0v
5      2.01v
6      2.01v
7      2.01v
8      9.08v
