3 volt piezo buffer
Started by anotherjim, June 03, 2016, 11:14:04 AM
anotherjim
Not many sub 9volt buffer circuits published. This is a basic J-fet, nothing special, but in view of the low supply V, bias is trim-able, so you don't have to select the transistor to get the best clean headroom. The one I built on perf uses a CR2032 lithium button cell in a plastic holder and the J201 is an smd one. High input impedance, so make sure the piezo/wires are well screened.
GibsonGM
Very nice, Jim.  :)  A good addition for the on-board electronics list.
Nice little circuit Jim
samhay
Would it not benefit from an input cap seeing as you have biased the gate above ground?
anotherjim
Sam:
Is an input cap is necessary for a piezo - it pretty much is a cap itself yes?
But you have me thinking - DC on the input cable could make it a bit microphonic? Hmmm....
I found the FET source voltage was too often very close to V+ with ground referenced bias. Seems to me, this becomes more of an issue the lower the drain (supply) voltage is.
If I fitted an input cap, it would be 1nF film. To stop the piezo (+) "floating", it would need a pull down resistor. If that pull-down were 10M, the net input impedance will be about 5M, still high enough I think. If it proves necessary, I'll update.
You may also notice there is no power filtering or polarity or input protection.
1   It's always going to be battery powered, and that is already a pretty good capacitor.
2   It's impossible for CR2032 to connect in reverse in a proper holder. Even if it was, the circuit is not damaged by reverse supply. Watch out for this if you build it -  it will still pass audio with reverse polarity! Guess how I know :(
3   It's always going to be connected to a piezo, so no input protection really required.
That said, to be a little more "professional", maybe a small series resistor should be in the output between FET source & 1uF cap - maybe 470R to 1K - to limit output fault current.
A piezo can be leaky and still "work". That skews your preset bias.
Because with large source resistor, happy bias Vgs will be very nearly Vgs(off). And Vgs(off) for many JFETs is 2V-3V, which on a 3V supply is like putting a 9 foot monster truck in a 7 foot garage.
You want to pre-select your JFETs for low Vgs(off).
anotherjim
Damn typos. R1 is 4k7. Sorry. Although I've tested 47k & it can work with that. I'll update the scheme soon.
Tried 3 different disc piezos and none of them change the bias when connected. If a piezo goes leaky, I'd rather it did show up as a fault, but it can upset the bias some without putting the source too close to either + or -. Adding an input cap is easy, but I'm doing without. Even with some cheap lapped screen cable (I don't recommend keeping the red/black wires some discs come with), the cable is not itself microphonic, although it can of course transmit vibration to the piezo if handled close to the disc.
anotherjim
