Weekend build ..need some advise
Started by copperheadroads, July 09, 2016, 01:34:57 PM
copperheadroads
I'm in the process of building this stompbox on vero (as a weekend project ) http://tagboardeffects.blogspot.ca/2016/03/madbean-turnabout-jhs-andy-timmons.html
it calls for a on/off/on switch & that is the only part I don't have .i Have a whole bunch of on/on switches would I be able to work around the switch difference & use my on/on switch & be able to get 2 of the 3 modes & when i get the proper switch swap it out .  how would i wire it ?    ..thanks.....
strungout
Using two of your on/on switches (one side of which would get grounded) is possible. Though its hard for me to tell without an schematic. Theyre a lot easier to interperate.
"Displaying my ignorance for the whole world to teach".
"Taste can be acquired, like knowledge. What you find bitter, or can't understand, now, you might appreciate later. If you keep trying".
As long as your on/on switch is an SPDT it should work fine, giving you just 2 of the 3 options. Wire it exactly the same as you would the on/off/on switch. "Sw 2" goes to the middle lug of the switch, "Sw 1" and "Sw 3" are arbitrary, just as long as they aren't on the middle lug. Hope this helps :)
