EA Tremolo mod with clipping diodes?
Started by Ben Lyman, October 02, 2016, 03:21:10 AM
Ben Lyman
Awesome, thanks Russ. I will try both ways when I make another one and see how it goes.
I'm not particularly crazy about blinking lights but it does seem like it might be a good way to hypnotize somebody into purchasing a pedal  ;D
        -S. Vai
from when we was messing with the pso before, I rekon IF you use a superbrite led, and IF you use a decent large CLR, like your 47k, across the 15k collector resistor, it should be tikkety-boo.
" I will say no more "
