Two loop switcher to compare pedals side by side
Started by disorder, October 10, 2016, 04:28:55 PM
disorder
I'd like to build a loop switcher with just two loops solely to compare two pedals. It seems simple, one 3PDT to switch between loop out and bypass and another 3PDT to switch between the two loops. Am I missing anything? Better way to do this? Suggestions?
intripped
disorder
Awesome. I should start a youtube channel comparing similar pedals and wear clown shoes to hit both switches at the same time.
intripped
_IF_ you can keep straight which-is-which without lights(!), I think this simplification of GGG's plan will work:
caspercody
Check out this site:
http://www.singlecoil.com/tb-strip/tbstrip.html
A lot of great information. I built a (5) channel true bypass looper using their schematics, and it works great.
Rob
potul
This is exactly what you need. Instructions in spanish, but you can google translate if needed.
http://www.pisotones.com/Looper/Looper.htm
Depending on how you connect you it can use it as an A/B box, A/B Looper or bypass looper
I use it all the time.
