op amp buffer phase switching
Started by Kipper4, March 18, 2017, 04:52:53 AM
I feel sure I've come across this before and should already know the answer but I'm having a total brain fart about it.
I have a spare half of an op amp in my circuit.
I would like to make one of the input NI buffers (coming from another Effect) and be able to switch the phase to an inverting.
How'd I do that?
I'm thinking DPDT switch.
Any links or help would help me dispel the proverbial brain gas.
Rich
Just for clarity this is AC signal.
KarenColumbo
#2
If it's okay to post a link:
http://sound.whsites.net/project107.htm
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
Sounds a bit Irish answering my own question but would this work, so it would....
Happy St Patricks day everyone.
There's a circuit at Geofex that does it with a single opamp and an SPST switch. I'm a bit "mobile" atm, so I can't do the search for you mate. :-}
Yep I know the one Marc. I'll try both later today.
All solutions gladly received.
The GeoFx idea doesnt work for this since there's a gain change on switching but it was worth a punt.
I've dropped the idea since it causes more problems than answers and I'll probably just use the spare op amp to buffer the Vbias.
Thanks anyway guys and girls.
Rich
anotherjim
The single amp idea should work without gain change...
Inverting input with x1 gain = Inverted output x1 gain.
Connect to the + input as well as the - input = Non-inverted output x1 gain.
Because if both + and - inputs of an op-amp have the same signal, if makes it a unity non-inverting buffer.
You are keeping the first op-amp to buffer it? It needs to be there.
Rbias and the input cap are not needed as the buffer outputs at Vref. R1,2 & 3 are the same (10k)
Ok thanks Jim I ditched the original buffer and implemented it without.
I'll put a buffer before it and try it.
The issue I found when I tried the kipper buffer (post3) Credit to SamHay there too.
Was that it caused a phase issue with the input buffer in the enveloped looper.
