Overdrive Pedal - First Design
Started by jfrabat, February 12, 2017, 11:21:17 PM
jfrabat
Quote from: PRR on March 09, 2017, 12:35:47 AM
> there is continuity from the signal to ground (the pots, the case, the ground, all over!
"Continuity" is for trailer lights.
We electronic techs have small and large resistors every which way. We need the difference of ZERO Ohms (wire), 10 Ohms, 50 Ohms..... most continuity beepers won't tell that.
Ah HA!  I thought there could be some of that!  OK, I will measure tonight.
I build.  I fix.  I fix again.  And again.  And yet again.  (sometimes again once more).  Then I have something that works! (Most of the time!).
jfrabat
Just did some trouble shooting; turns out it was not a short.  I made a mistake in the board, so I have to redo it...  The schematic was correct, but the PCB I drew wrong.
