reapir part needed 161-0087-e Kobiconn
Started by mozz, March 25, 2017, 11:50:44 PM
mozz
Anyone know where i can get a discontinued part? It's a 161-0087-e Kobiconn. 1/4 headphone jack with 2 spdt switches.
The pedal is a red witch deluxe moon phaser, there is no stereo ouput, if you plug anything in the stereo jack the regular output goes dry, while it should stay wet. This vertical jack has 8 pins and ground, real oddball. I emailed the company but they want serial number, place of purchase etc etc, i told them it's used and out of warranty and then the emails stopped. Pretty sure this part is bad, cant unsolder without lifting traces and melting plastic, i can cut the old one out if i get a replacement. It listed on Mouser as obsolete. Anyone, Beuhler?
mozz
You wouldn't have a picture of the bottom would you? Or can tell me if it's the exact part number, looks like it. There are 8 connections and the ground.
smallbearelec
mozz
Yes that looks like it, i ordered a pair. I finally got it unsoldered, boy i hate this lead free solder and ribbon cables.
Thank you very much, you got a new customer.
