King Dubby Delay - Low output volume
Started by guidoilieff, April 25, 2017, 11:30:34 PM
guidoilieff
1.What does it do, not do, and sound like? Does everything fine except the low volume at the output and repetitions are distorted. After the 33ohm resistor the voltage drops from 8.50v to 7v
2.Name of the circuit = King duby delay
3.Source of the circuit (URL of schematic or project) = http://effectslayouts.blogspot.com.ar/2015/09/king-dubby-delay.html
4.Any modifications to the circuit? No
5.Any parts substitutions? 20k resistors replaced with 18k (20k are not standard values in Argentina)
6.Positive ground to negative ground conversion? N
Voltage at the circuit board end of the red battery lead = 8.50
Voltage at the circuit board end of the black battery lead = 0
Q1
I = 7v
G = 0v
O = 5v
Q2
C= 0v
B=3v
E=2.50v
Q3
C=0v
B=3v
E=2.50v
IC1 Tl072
P1 3.45v
P2 3.45v
P3 3.45v
. 0v
. 3.45v
. 3.45v
. 3.45v
. 7v
Q2 (pt2399)
5v
2.50
0
0
3
2.50
0.66
0.66
2.50
2.50
2.50
2.50
2.50
2.50
2.50
2.50
Q3
Idem Q2
1N4007
Cathode 7v
Anode 0v
D1 and D2 1N4148
Cathode 0v
Anode 0v
I dont know where is the problem. I already replaced Ic1,2 and 3.
Thanks for your time. I appreciate it.
guidoilieff
guidoilieff
Look at those transistor voltages. Are those weird values?
nocentelli
Quote from: guidoilieff on April 27, 2017, 11:05:14 PM
Quote from: guidoilieff on April 25, 2017, 11:30:34 PM
Q1
I = 7v
G = 0v
O = 5v
If Q1 is the regulator, I is supposed to be connected to +9v which you've posted as 8.5, yet is only showing 7v so something is clearly not right there.
antonis
Quote from: nocentelli on April 28, 2017, 12:56:12 AM
Probably 7V appear after 33R resistor so a 45mA total circuit current should be considered OK..
guidoilieff
Q1
I = 7v
G = 0v
O = 5v
QuoteProbably 7V appear after 33R resistor so a 45mA total circuit current should be considered OK..
That's exactly what happens. Also tried 3 more delays and they all work fine with 8.5v.
guidoilieff
Did I miss something in my report? Everything looks fine? Would a picture help?
