VB-2 Ramp Function
Started by rthryhorysak, May 03, 2017, 09:47:37 AM
rthryhorysak
So I was looking at the ramp function that the Boss VB-2 has, and based on the knowledge (or lack thereof), it seems to be a VCA controlling the voltage depth of the LFO. Correct if I am wrong about that, but I wondering about the other part of the ramping. So is that ramp circuit outputting a voltage that completely opens the VCA and the rise pot in conjunction with the diodes delaying that voltage? I am not familiar with anything similar to it so if someone could explain it to me I would greatly appreciate it, and if there is a way to simplify it as well. Thanks
This is the schematic from BYOC, the boss is a little different, but I assume that's because of the bypassing of the boss. Also sorry for the poor quality.
anotherjim
D5 and D6 are acting as steering diodes (If I read numbers correct).
With increasing control volts, C26 charges via D5 at a rate set by VR3. When control falls, C26 discharges at a fixed rate via D6.
rthryhorysak
Quote from: anotherjim on May 04, 2017, 06:30:32 AM
Ok, interesting, thank you. What is that transistor network on the control input of the VCA?
anotherjim
Q10 & Q11 = current sink.
Q12 & Q13 = current source mirrored from Q11.
? That's my guess, I've never seen so much in an OTA control before. Some Boss circuits look like they were trying to clear a surplus of parts, though I'm sure there's a good reason for it really.
rthryhorysak
Well this is the BYOC schematic. On the Boss schematic R55 (33k) goes right to the control input of the OTA
armdnrdy
Quote from: rthryhorysak on May 04, 2017, 02:58:26 PM
That is because the original Boss circuit uses the BA662 which is very rare these days...
The "extra" transistors are due to making the BA6110 work in its place.
I believe that synth guys working on a BA662 replacement for the x0xb0x came up with this work alike.
anotherjim
rthryhorysak
#7
Quote from: armdnrdy on May 04, 2017, 03:36:48 PM
Is it possible to use something like an LM13700 or a CA3080 in place without having to rework the BYOC schematic? I cannot find a datasheet for the BA662, but I was reading some forum posts saying the 3080 is a good replacement for the BA662 despite the sonic quality. However, since it doesn't process the audio signal at all, not a big deal, and the 13700 is close to 2 3080s...
Fender3D
rthryhorysak
For anyone interested, I picked the Behringer clone and they are using a V13700M for the OTA with the 33k resistor going straight to the Bias Input.
