high note sustain fuzz?
Started by blackieNYC, April 10, 2018, 08:44:29 PM
blackieNYC
What pedal am I looking for, to get a long, saturated sustain when playing high single note passages? Sometimes the low end sounds so smooth but the high notes don't have so much sustain. They get tired and peter out early.  I was thinking of hitting the front end of a fuzz face harder.  Perhaps an op amp and a pickup sim?  Or maybe just a BMP version.
thermionix
Fuzz Factory and BMP can do some serious sustain.
iainpunk
Most opamp fuzzes seem to work, or a rat dialed to 11
cheers
KarenColumbo
I just built a BMP with a pre-gain booster (a LPB1) - good sustain even on high notes
I see something of myself in everyone / Just at this moment of the world / As snow gathers like bolts of lace / Waltzing on a ballroom girl" - Joni Mitchell - "Hejira"
blackieNYC
Good ideas, thanks.
If I wanted to put an LPB1 in front of a fuzz face, would it be best to add a pickup sim (one transformer coil) - or would that created enough signal loss to offset much of the boost?
Boosted BMP sounds like a lot of distortion- but it stays smooth and under control?
Danich_ivanov
#5
I built similar to big muff circuit (2 stages out of big muff) with mosfet booster (basically sho) as a first stage, and it had plenty of sustain, so maybe something in that ballpark. As far I understand the whole thing, sustain depends a lot on how [square] you'r signal is, so perhaps playing around with Schmitt Trigger within distortion/fuzz circuit might give interesting results.
Another thing that comes to mind is adding a network of low pass filters before or after first stage, nothing crazy, around 10k with 10nf cap, 2 of those, and make things brighter in the end. On the other hand, in a big muff circuit you can increase 470pf caps to something bigger, or/and play around with 100nf cap that goes in series with diodes and get somewhat similar results.
candidate
