painting boxes
Started by Brian Marshall, November 09, 2003, 01:44:28 AM
Brian Marshall
any good articles or sites about painting boxes?
I've only found a couple that were slightly helpful, but not very detailed.
brett
Don't forget that your local powdercoater might do your boxes with powder left over from major jobs for a very modest fee.
Otherwise, auto paints are good quality at a reasonable price.  Hammered metal finishes are good if you are less-than-expert (like me).
Brett Robinson
idlefaction
hrm.  :/
i sand my boxes with 600 grit sandpaper, then do a coat of fast drying aluminium primer spraypaint.  that stuff dries in about 20 minutes.  i always find though that in the 20 minutes it takes, miscellaneous crap has managed to stick in the paint (dust, bits of leaf, random floating crud) which is so annoying!!  :P  it's good to preheat the oven while this is drying.
then i do a coat of normal enamel spraypaint and bake it in the oven at 90 degrees C for about an hour, then another coat and bake.  i don't wait for it to dry or anything, just spray and stick straight in the oven.  i did five coats once, but now i don't bother cos it still chips off the same  :(  (i only do two coats cos the stuff i use looks better that way)
then i put on lettering and do a coat of clear plastic spray and bake that the same, 90 degrees C for an hour.
it looks really good, but takes so long, and still chips off easily  :(  any advice appreciated...
Darren
NZ
bwanasonic
Steve's *Tweako* photo essay has a bit about finishing:
http://www.smallbearelec.com/Projects/TweakO/TweakO.htm
I've been meaning to try the epoxy clear coat he uses. If anyone has a brand name and source for this stuff...
Kerry M
Sometimes these guys can be very friendly and helpful.
 See if you can have one call you when they're doing a [say blue metal flake] finish coat you might like on you box.  For cheep [I would offer 5-10 buxx] they can just turn around and spray you r little box in a minute, using the setup they have all ready for the car.
 I like the clear or glossy Nitrocellulose Laquer best for getting the final hard clear coat's' on there. I can get it to look like glass almost. The N.L. is easy to werk with [IMO] cause it goes easy and can be multicoated for a supeer thick, gleamy, hard coat.
 Powder coat is probably the hardest ....          ?
