Surf Green Acrylic Spray Paint? (UK)
Started by steveyraff, September 13, 2018, 02:18:30 PM
cab42
This beautiful diy guitar from a german forum uses Color code RAL 6027 for surf green.
https://www.gitarrebassbau.de/viewtopic.php?t=2291
You Can find this in Lots of european webshops
Belton and Motif are a couple of brands I have seen.
"Rick, your work is almost disgusting, it's so beautiful.  Meaning: it's so darned pretty that when I look at my own stuff, it makes me want to puke my guts out."
Ripthorn
checkout some small independent car parts shops...
i have a little local one, not much choice, but what he does have is pretty good...
and i always use his clear on various stuff...
top tip: if you ever need matt black, poundland.  8)
thermionix
And matte black will become gloss black if you buff it, or spray gloss clear over it.
steveyraff
Quote from: thermionix on September 18, 2018, 05:47:09 PM
Yea, I do that sometimes. You can also spray Matt lacquer over gloss coats to make the finish Matt.
Steve.
www.outlandstudios.co.uk
thermionix
A general advantage of matte/flat paints is that they go on thinner and dry quicker.  Solids:solvent ratio.  Really good for the first coats even if you ultimately want something glossy.  But waterslide decals want to go onto a glossy surface, so there's that to plan around.
