help designing quiet buffer/preamp - which IC?
Started by tempus, March 26, 2019, 02:25:29 PM
tempus
Hey all
I'm thinking of building a buffer/preamp for the piezo bridge on my electric guitar. It would obviously require a high input impedance, so a TL071 would handle that nicely as a buffer. I would also need some gain there though (I want to bring it up to line level), but I'm not sure which of these 3 scenarios would give me the lowest amount of noise:
1. single TL071 with input impedance set to, say, 5M with feedback resistor to set gain to the appropriate amount (if I can get a high enough value resistor)
2. TL072 with one opamp configured as a buffer, and the other set for the required gain
3. TL071 configured as a buffer followed by a low noise opamp like a 5534
Which would give me the lowest noise? Any other (possibly quieter) solutions?
marcelomd
Hi,
If you insist on a FET opamp, try the TLC2272, a "newer" TL072. It's lower noise and rail to rail.
Also, the lowest noise (affordable) opamp I know is the NJM2068. Better performance and lower power than NE553x.
tempus
Thanks for your reply Marcel.
The only reason I'm considering the FET opamp is that I don't think a non FET opamp will be able to give me the input impedance I need. My pickup specs the impedance as 1.3M at 100Hz.
I'll look into these other opamps though.
Low hiss for low-Z sources, 1K-30K impedance.
High hiss for high impedances like Piezos. I bet a TL072 will do better. The TLC2272 is pretty spiffy at 0.6 fA/√Hz. OSI computes at 15Meg, which is in the best ballpark for Piezo.
Quote1. single TL071 with input impedance set to, say, 5M with feedback resistor to set gain to the appropriate amount (if I can get a high enough value resistor)
You don't want an inverting configuration.  They won't be lowest noise.
Lowest noise:
- JFET input opamp,
- non inverting configuration,
- gain in first stage (not two stages) with low valued resistors in feedback network
marcelomd
Quote from: PRR on March 26, 2019, 08:19:26 PM
True. Never used them as first stage. I thought, but did not write about using a JFET buffer before the gain stage.
Still, TLC2272 might be the better option.
antonis
Quote from: tempus on March 26, 2019, 06:39:57 PM
By bootstrapping you can get very high input impedance..!!  :icon_wink:
(both for BJT & FET input op-amps..)
Split single bias resistor into 2 separate resistors (2X100k should be OK for noise preventing purpose) and connect a 100nF (or bigger) cap between the junction of those resistors and op-amp output/inverting input..
