Best Place to Get Matched Fets
Started by GreySuits, August 19, 2019, 02:31:01 AM
GreySuits
Building a Phase 90 and I need 3 matched Fets.  Small bear has 4 for $10.95, is that the I can do pricewise?
radio
Small Bear has 4 matched fets for P90 phaser because you need 4
Keep on soldering!
And don t burn fingers!
bettsaj
"My technique is laughable at times. I have developed a style of my own, I suppose, which creeps around. I'll never be a very fast guitar player."
italianguy63
I built a ROG JFET tester a few years back.. I just use that!
MC
GreySuits
Quote from: italianguy63 on August 19, 2019, 09:27:24 AM
MC
I saw a video on that, how many fets did you have you have to go through before you found 4 matched ones?
iainpunk
i usually get a large batch (30 or so) jfets and test them all, arrange them from low to high threshold Voltage and tape the plastic parts between painters tape, like an ammo belt, and write the test results on the tape.
i use a lot of jfets, really a lot, because i like the tone of certain jfet based gain stages (see pic related) so i can justify ordering a large batch of em, i dont know what your stance is on jfet use for almost all gain stages in your pedals, if you donĀ“t like that prospect, buy the 4 pack from smallbear
cheers
