Fixing Boss CE1
Started by nvera005, September 17, 2019, 01:33:38 PM
nvera005
Hi everybody,
I was experimenting with pedal chain-placement and I put my Chorus pedal (boss ce1) after my Fuzz and Distortions into the front of my amp not FX Loop and I hear that my CE1 is now less powerful than it was before. When I started using it again it basically almost didn't work. It sounds like a fuse blew out.
I would greatly appreciate somebody help on this.
Scruffie
At 40 something years old, it's very probably just a dried electro but if you want more information, we need more information.
Photos and voltage readings would be a good start.
nvera005
Thanks so much for responding. I actually troubleshooted it all day and discovered that when I put it in the FRONT of the amp it restored its juice and is working again. It just didn't have as much juice in the FX loop when I put it back (Marshall dsl20hr). I was very worried as its a very special (and expensive) pedal. I thought I almost lost it!
Again, thanks so much for responding. I now am tasked with organizing it in my pedal chain in proper and safe order.
If you have anything at all to add I would love to hear it.
MrStab
hi nvera,
this still doesn't sound normal, and the problem may occur again. is your FX Send set to instrument level (-10dB)?
Recovered guitar player.
Electronics manufacturer.
