Hex inverter DIP8 package?
Started by Chugs, August 25, 2018, 07:28:20 AM
I don't know why but I checked the datasheet for the CD40107.    The datasheet says it's a *NAND* gate.   the chip's identity has morphed over the thread from an inverter to the NOR gate.  You should update the schematic.
So that means on the reset circuit you need to connect the R to VCC and the C to ground.
Also, the output of the gate which has the reset circuit connected will go *high*  at power-up.
The LED goes on when the output goes low, so the LED  which you want to come on at power-up
is the gate *without* the reset circuit connected it.
Pitchfork
Thank you for the excellent advice
This is what I have come up with & it operates very well
QuoteThis is what I have come up with & it operates very wel
l
Cool.
Should the R10 (4k7) connect to pin 2?
iainpunk
i know that its kinda off topic but the thread title annoys me a little
its called a hex inverter because it houses 6 inverters, when using a dip8, the maximum possible inverters is 3, so it can not be a hex inverter chip it it is dip8
im sorry, my autism couldn´t let me go further without saying this
cheers
Pitchfork
The initial question related to Hex Inverters but then the suggestion to use a Dual NAND gate (CD40107) which was in an 8 pin DIL pkg as an alternative solution was posted, from then onwards the subject changed to how to use this device (and I am very grateful for the advice given)
